Electric Aerial issues
Started by Miked, October 21, 2010, 14:25
Miked
i've just go myself an 2003 roadster and the electric aerial doesn't work. when i turn on i get the whiring noise but the aerial doen't come up. i have also tried manually pulling the aerial up but it won't budge.
any ideas on a solution, or is it simply bust and i need to get a new one. also is there any way i can get it up manually until it is fixed. the car is fitted with an Alpine head unit.
thanks.
you probably need the aerial insert, the plastic bit.
I think you can buy it as a spare, cheaper than a aerial
Everything you need can usually be found by using the search button in the top corner but here's a couple of links to start you off.
 l viewtopic.php?f=11&t=30484&hilit=+aerial l
 l viewtopic.php?f=9&t=21983 l
Try these  l viewforum.php?f=57 l  or  m http://cgi.ebay.co.uk/TOYOTA-MR2-MR-2-E ... _500wt_922 m
wbarrwebster
Hi,
Suggest you take the chrome screw  from the top, switch  the radio on, if the mast won't come up, chances are the white toothed plastic tail of the mast is broken.
Switch the radio on and attempt to pull the mast up, If you can get the mast up with the tail, you can buy a replacement from Mr T for about £40. All you do is push the white plastic tail  first with the mast into the aerial after switching the radio off....the aerial will pull the mast down....great!
Chances are they'll be a bit of the white bit still in there....if you want to do it properly, the aerial has to be taken apart.
Please search, Liz did the work previously and there are pics there as a guide.
Hope this helps.
B
W. B. Webster
