One touch electric passenger window
Started by Anonymous, December 13, 2010, 21:13
Is it possible to modify the passenger window to one touch operation, like the drivers side?
nathanMR2
Yes i think theres something on Spyderchat about this. You'd need to search there.
I looked at it and thought it was too much effort to bother with it if im honest
JiMR2
Pretty sure it involves replacing the window motor/relay for that side... As Nath says, lot of work for what the end result is...
AKA Cinnamon Jim
cclarke99
The easiest way to do it would be to get a body ECU and a switch from a scrap car (probably lots of Toyotas use the same part) and just reproduce the drivers side circuit on the passengers side. One thing that would help is that there are the same number of wires (5) going to both switches, so you would not need to add any wires. It would involve a fair bit of fiddling around under the dash, etc, but you should not have to dismantle the doors as the motors should be the same. I could provide more details if you decide to go this way
Alternatively a lot of cars have a separate relay to do the job which you could use. See
 m http://www.sportingfords.com/forums/vie ... f=16&t=673 m
All it has to do is keep the motor running after the switch is released until the motor current increases as the window shuts, and then turn the motor off. The only problem I can see with this is that different motors may have different thresholds to switch off. For this reason it would certainly be best to use one from a smaller car.
glenonoka
Not sure if you have viper alarms over there. I have the additioanl window module for teh alarm and both my winodws are now one touch up/down if you lift the switch very briefly. Otherwise the switch behaves normally.
Quote from: "cclarke99"The easiest way to do it would be to get a body ECU and a switch from a scrap car (probably lots of Toyotas use the same part) and just reproduce the drivers side circuit on the passengers side. One thing that would help is that there are the same number of wires (5) going to both switches, so you would not need to add any wires. It would involve a fair bit of fiddling around under the dash, etc, but you should not have to dismantle the doors as the motors should be the same. I could provide more details if you decide to go this way
Hi - thank you for this info. I have looked on spyderchat whereby  a guy has designed a module to simultaneously open or close both windows, however 'd prefer not to have a separate switch to do this, but rather source a drivers side window switch that is illuminated, creating a factory look.
Please post up the details, when you get time, as I'm sure other owners would like a way of doing this. Many thanks   s:) :) s:)
cclarke99
Ideally as well as the drivers switch and body ECU, you'll need the matching connectors from the loom. Contrary to my earlier suggestion, if you can get the connector for the drivers switch then it might be best to run new wires through as it's not that far, saves destroying the existing wiring and you can keep the window lock function.
Install the new ECU as near to the old one as possible
You'll need to locate the wiring where it goes from the switch to the passengers door, which you should be able to find under the dashboard below the main fusebox. Cut the red and green wires (normally they go to the window motor) in a place that means you can easily reach your new ECU
If you're going to re-use the wiring to the passengers side switch do the following
   Locate the wiring to the window lock switch which goes from the window switch up behind the centre console. cut the Red/Blue wire.
   Locate the blue wire where it goes into the body ECU (located under the dash adjacent to the main fusebox) and disconnect it from the ECU.
Identify the connections to the new ECU as follows
   Connector A is the larger connector with 6 pins larger than the rest; Connector B is the smaller with all connections the same size
   The switch connector is called P4
Connector A B P4
Top right pin 1 1 1
Top left 13 8 2
Bottom right 14 9 3
Bottom left 25 18 6
To wire up the new ECU you need to make the following connections
New ECU
pin Function Connect to Wire colour
B13 12V window power Existing ECU B14 (Black wire)(2)
A15 12V control Existing ECU A15 (Red/Black wire)(2)
A24 Ground Existing ECU A25 (White/Black)(2)(3)
B9 Auto down P4-5 (Blue/orange - Red)(1)
A24 Down P4-4 (Blue - Green)(1)
A12 Up P4-6 (Blue/Black - Blue)(1)
B12 12V switch light P4-3 (Blue/Orange - Red/Blue)(1)
B 4 Window motor down Wiring to door (Green)
B 5 Window motor up Wiring to door (Red)
(1) First colour refers to the colours on the drivers switch loom, second is a suggestion if you're using the  existing wires
(2) Splice the new conenction into the existing
(3) Or you can use any handy ground point
On the switch, P4-2 should be wired to earth. If you are running new switch wires, you can use the Red/Blue wire to the passengers switch as your earth. If the switch is in the window disabled position, the the switch light will go out (something Toyota should have done given the number of passenger window "failures" from this cause?)
Finally a word of warning - this is all "armchair engineering" working from the circuits and not having looked at the car (it's too cold outside) - make sure it's all feasible before you start cutting wires.
If anybody has anything to add to the above then I'd be pleased to hear
Quote from: "cclarke99"Also the editor mashes up all my lovely tabbed tables - if this is confusing, I can provide the original text
If you put the piece of text you want tabled in [code], it'll keep all the original formatting. Not sure if that's what you're after or if you knew that already and it still didn't work.  s:) :) s:)
cclarke99
QuoteIf you put the piece of text you want tabled in [code], it'll keep all the original formatting
Thanks for the advice, I didn't know that and it looks much better now
