Audio pins out required...
Started by vatovey, January 6, 2011, 19:53
vatovey
Evening all,
I have got a new stereo for the mr2, it's a chinese knock off on eBay... does everything, DVB-T, Sat-Nav etc...
The cable the stereo has come with has a standard ISO connector on one end and a custom connector which fits in the stereo on the other end.
Unfortunately, the MR2's audio's connector is not of the standard ISO type so am unable to simply connect the cables up, due to this I am gonna have to solder the cables together.
I know what the cables do on the stereo as I have the circuit diagram, unfortunately - I don't have one for the MR2.
Could anybody advise as to what cables do what on the MR2 audio, I can work some out as they are easy enough.
ie.: Grey & Grey/Black along with White & White/Black are speaker cables.
Black - Ground, Red and Yellow are permanent and switched live respectively, am not sure what the Blue, the Blue/White or the Orange/White cables do.
Thanks, Vaughn.
cclarke99
The colours are in this post
 l viewtopic.php?f=31&t=30080&hilit=+radio l
vatovey
Thanks for that - much appreciated.
Strangely, my wiring colours are slightly different.
I have the following.
Grey & Grey/Black - Speaker wire
White & White/Black - Speaker wire
Black - Ground
Red - Power
Yellow - Power
Blue - ???
Blue/White - ???
Orange/White - ???
My MR2 is a 2000 model also....
vatovey
I have found the answer.
Grey - Front Right +
Grey/Black - Front Right -
White - Front Left +
White/Black - Front Left -
Black - Ground
Red - Switched Live
Yellow - Permanent Live
Blue - Power on Antenna
Blue/White - Power on Amplifier
Orange/White - Illumination
