In the sh*t with my ONLY car key...
Started by Patch, January 9, 2011, 19:33
Patch
My missus borrowed the car last night.  When it came back, somehow, she'd managed to lose ONLY the guts (electrics) from the ONLY key I have!  I don't know, and she doesn't know, how or where the electrics went.  It's a ONE BUTTON key (with the key located on the edge, not the face, of the key) - and I haven't been able to find anything on that type of key online.
Luckily, my car has an aftermarket alarm/immobiliser with a separate fob, so I can still lock and immobilise the car.  BUT - I'd stopped using the fob a while back 'cos the alarm was going of during the night.  Not looking forward to tonight in case the alarm starts going off...
Anybody know how I'm going to go about getting a new key incl. internal electrics for my car?  I've  got a terrible feeling I'll need to start removing door panels and finding ref numbers on the barrel of the lock...    s:? :? s:?
I know this ain't gonna be cheap.  Missus will be getting the invoice, though.    s:evil: :evil: s:evil:
michaelasaunders
I reprogrammed my spare key which did not work any more based on this topic. (Thanks Les!)
 l viewtopic.php?f=47&t=23563&p=293161&hilit=+key#p293161 l
However, there is an option in the link below for only one key with no electronics. CTP (Cheap Toyota Parts) Hopefully they are still in business, as I have not contacted them before.
 l viewtopic.php?f=57&t=21417 l
Regs
Michael
Fiat Stilo 1.9TD 53 plate - 3 door - red
Ex-MR2 - X reg, Blue, Hard Top
calaerial
I cant begin to understand how one would lose the innards from a key....
Work in progress - 2001 MR2 Roadster - Silver
Current faults:
General dings
Rotten brake discs
Sticky aerial
Rowland
UK or Japanese car?
Whereabouts are you located?
When I lost my keys these guys got into my car and had it running in under an hour leaving me with two keys too!
 m http://www.wchildslocksmith.co.uk/ m
Uk or JDM, immobiliser or not, they guaranteed they could help me out.
  s:) :) s:)
frogger
All of the below assumes you have an import :
The only time things are immobilised on an import is when you use your seperate alarm fob - this activates the immobiliser and the alarm.
The button on the key just does the same as sticking the key in the lock and turning it (meaning not having key electronics is an inconvenience rather than a show stopper).
By using the stock toyota key button you have just been locking the car, not immobilising - i.e. the same action as using the key.
So you have no less functionality now than you did before you lost it (just have to put a key in a lock rather than push a button to achieve it).
So... Best thing to do is get the aftermarket alarm/immobiliser sorted if it's going off randomly. The 'stock' security on the car is pretty basic (to say the least) without an aftermarket security system. And all UK insurers also demand CAT1 immobilisation on import MR-S models, so if your not using it (a) your car is a hell of a lot easier to nick, and (b) if it was nicked your insurance would probably try to wriggle out of the claim.
Once you are using the aftermarket alarm/immobiliser then all functionallity of the key is redundant anyway (with the exception of using it to turn the engine over!) so there's no real worry about replacing the electronics - Quite to the contrary, on import MR-S models having the stock electrics still IN the key can occasionally screw with the alarm system! As if pressed you can send the deadlocks out of sync with the instructions of the aftermarket alarm .
If you have a UK model - Ignore ALL of the above   s:) :) s:)
Patch
I definitely DO have an import.  But the immobiliser DOES arm itself after the engine has been turned off for 20 seconds.  The only way to dis-arm the immobiliser is with the alarm fob.  (You have to do this even if you haven't turned the alarm on with the alarm fob).
frogger
Yeh, mines the same. Sounds like you just need to be using the alarm fob for everything anyway (like all the imports really)   s:) :) s:)
