2ZZ loosing water
Started by Anonymous, January 22, 2011, 15:16
my mates celica vvtli is losing water any idea what it could be?
muffdan
A leak somewhere  s:) :) s:)
Is it leaving puddles on the drive if left standing? How quickly is it loosing water?
Ilogik
A BIG HOLE!
Heater matrix, rad, over heating?
Ex: TRD stage 1 TTE Turbo
engine losing water, i think its either the head gasket starting to go or there's a plastic pump in the top that's broken. hopefully we can narrow it down.
Ilogik
get it pressure tested.
muffdan
Quote from: "Ilogik"get it pressure tested.
yes, a leak down test and compression test is the way forward. You'll have a good idea if it is the head gasket after that. Has it run out of water previously or suffered some other circulation failure?
Quote from: "muffdan"
pressure test? is it just plugging in the tester into the where the spark plug are? if so what pressure is good? oh and lastly how much does it cost to repair the headgasket or plastic pump in the top thats broken
ChrisGB
Depending on age, it could be the radiator. If it is similar to the MR2 one, about 6 years seems to be about as long as they last before starting to crumble.
Chris
DannyN
Hell, my was crumbier than a sand dune !!
[/size]
Quote from: "ChrisGB"Depending on age, it could be the radiator. If it is similar to the MR2 one, about 6 years seems to be about as long as they last before starting to crumble.
Chris
Nooooooo!
Mine is 8 years old now   s:( :( s:(
muffdan
I changed my rad last year because I felt that after 10 years it wouldn't have much life left even though it was working fine. I think having the air-con rad in front of has helped preserve it.
DannyN
Quote from: "Les"
Chris
Nooooooo!
The whole bottom 3rd of mine was practically invisible, Russ has a link for a replacement and it worked like a dream
[/size]
