Is an amp needed?
Started by Krissg, January 30, 2011, 09:10
Krissg
I'm wanting to improve my audio, I'm going to mount 2 6x9 speakers in the rear bin doors, I just wondered if anyone knows if I will require an amp to power them? Cheers
2003 MR2 Red....watch this space!
Ex- MR2, black MSD kit.
stargazer30
If you really want to improve the sound then give up on that idea.  6 x9s are nasty at the best of times but mounted behind the driver makes them worse.  Save your money buy a small amp and a decent set of 6.5 components for the doors instead.  Also a must is to sound deaden the doors (cover any holes) will sound much better.
Krissg
Quote from: "stargazer30"If you really want to improve the sound then give up on that idea.  6 x9s are nasty at the best of times but mounted behind the driver makes them worse.  Save your money buy a small amp and a decent set of 6.5 components for the doors instead.  Also a must is to sound deaden the doors (cover any holes) will sound much better.
I got the car with upgraded component speakers and tweeters but Isn't really enough, was going to go down the active sub route but was after more quality rather than a bassey noise. Why do you say 6x9 are bad behind driver? Cheers.
stargazer30
Ah makes more sense now.  if you want to use the 6x9s for bass and you have decent components already thats better.  You'd still be better off with a small sub though.  I had a 4 channel JBL amp in one bin which fed the components and the sub.  The sub was an 8" one in a custom box in the other rear bin.  Worked quite well.
AmeR
Or..... Underdash! Hear they're quite good, and keep the bins free!!
Krissg
Quote from: "AmeR"Or..... Underdash! Hear they're quite good, and keep the bins free!!
Well I'm waiting on one coming up but seem rare!!  s:( :( s:(  I'm also a sucker for a bit of colour coding and with my new green calipers found some nice fusion speakers that would look cool,
It's a bit more work to fit them rather than a sub I'm just trying to keep as much luggage space free as possible for my euro trip, after that the bind are going!  s:) :) s:)  ha
