Switch Advice
Started by skinz, February 17, 2011, 11:15
skinz
Alright guys,
Last year I hooked up my aerial to a rocker and had it wedged below my HU, anyways as I predicted at the time the switch keeps on moving out of place. My question: is there a toyota switch that I could obtain from a well-known auction site that will fill one of the blanks next to the steering wheel (similar to this:  m http://cgi.ebay.co.uk/toyota-mr2-roadst ... 19c328e05d m ), which would accomodate the aerial operation?
Would this be easy enough to wire? or will I need to dismantle dash? - Ive got the wires coming out HU and main loom so I guess its just a matter of feeding these behind the dash?
Also how do the blanks come out? push in/ push out?
S
Mike_V
I had to do the same with mine, the blanks push outwards and you can access them by removing the gauge cowling around the speedo etc, it just pulls off. This will allow you to remove the release the lower dashboard section to access the blanks, feed your wiring behind that section of lower dashboard and to fit your switch. I have no photos of this but have a look at it, it's simple enough.
2004 Red edition in Sable.
skinz
Mike, thanks for the speedy response, will have a look when I get home. Do you think that switch is ok? or could you reccommend anything better?
S
Mike_V
Switch should be ok but I bought a rocker switch (halfrauds) to correspond with the aerial position, press in at top, aerial up, press bottom, aerial down. You may have to use a touch of glue with these though as i'm not sure if they have the lugs that clip into the dash.
ChuckyBru
Quote from: "skinz"My question: is there a toyota switch that I could obtain from a well-known auction site that will fill one of the blanks next to the steering wheel (similar to this:  m http://cgi.ebay.co.uk/toyota-mr2-roadst ... 19c328e05d m ), which would accomodate the aerial operation?
In short, yes!
These were a common switch type fitted to many Toyota/Lexus'.  The tricky part is finding one to suit.  The one you've put a link to would work... only the icon on it may not be what you're after. I bought a couple of Lexus heated seat switches from ebay.  They just slotted strait in (after a bit of head scratching trying to work out which terminal was which).
[size=85]Charlie
2001... with added
TTET. [/i]
My fuel consumption.[/size]
kentsmudger
Do you actually need the passenger window lock-out function? You could use the switch that is already fitted.
skinz
Quote from: "kentsmudger"Do you actually need the passenger window lock-out function? You could use the switch that is already fitted.
this might actually be a better option, never used this switch at all :p - take it I can just tape up the wires in the existing switch then just connect the 2 for the aerial? - sorry need this in early learning centre terms :p
S
ChuckyBru
Quote from: "skinz"
S
I'm sure I'd seen something in the "how to" section on this, but can't find it now if it ever was there!  Basically you need to find which cable coming out of the back of the stereo is the aerial control cable.  I *think* it was blue on mine, but its a while ago now so don't just take my word for it.  A bit of trial and error may be required here unless some else knows which one??
  • You need to cut that wire and extend the two ends to the back of the switch.
  • Take the switch out and cut it off (there's only two wires going into it) and join those two wires you just cut so the window switch is now permanently live.
  • Take the two newly extended wires and attach them to the switch you just cut off (it doesn't matter which way round the wires go).  For joining the ends soldering is best, but terminal block or taping them up with electrical tape will work as its only a low current signal wire.
  • On a safety note, if you're not comfortable with what you're doing may be wise to disconnect the battery.  The worst you could probably manage is shorting something and blowing a fuse, but better safe than sorry!
Now enjoy the fruits of your labour - an aerial which goes up only when you want it to!
[size=85]Charlie
2001... with added
TTET. [/i]
Quote from: "ChuckyBru"I *think* it was blue on mine, but its a while ago now so don't just take my word for it.  A bit of trial and error may be required here unless some else knows which one??
Jason (enid_b) also did this a while back. Yes, seems it is the Blue wire.  l viewtopic.php?f=31&t=5453&start=46 l
Fatbloater
MR2 \'Red\' Edition - \'54 Reg.  Mods : Clarion FZ709E Single Din Stereo, Pre-cats Removed
"WAX On - WAX Off"
skinz
Cheers chucky
I connected the aerial to a rocker before so alreay got it from the loom, but just couldnt find a suitable place to keep switch, will get some more lengths of wire and try hooking it up to the window locking switch - then its just the matter of making up a suitable sticker to cover existing one  s:) :) s:)  - schimples... me hopes  s:) :) s:)
