Alarm Components Euro Import Help required
Started by mikecobra427, February 21, 2011, 21:50
mikecobra427
Looking for some help.
I have recently purchased my second roadster which is a European import and does not appear to have had an alarm fitted on entry.
My other roadster (now girlfriends)* has the TVSS alarm sounder inside the spare wheel well and the plungers on the frunk/engine cover and I was hoping someone might be able to give me a list of the other parts that make up the alarm ideally with part numbers if possible as I would rather just try and get salvaged parts and use the original key and not have another fob on the keyring.
The car has standard imobilizer (well at least a light flashes on the dashboard anyway) and remote keys which works fine and deadlocks the car if lock pressed twice but no alarm set. (oviously as it hasn't got one).
I have done a search for alarm and it appears that there is a microwave sensor behind drivers seat under the carpet. Also there is an led on the right hand side of the dashboard (at least there is on the other car) but what other parts make up the system? Is there another seperate box running the alarm or is it built into the ecu/immobilizer. Does anyone have a wiring/component diagram of the TVSS system?
Thanks in advance for any help given.
*She has already been done by the local constabulary doing 67 in a 50 - £60 and 3 points!
Mike
Treboeth
 m http://www.toyota-tech.eu/Aim.aspx?menuitem=1 m
I think this is the link you want Mike sorry to hear about the plod  s:( :( s:(
mikecobra427
Thank for the quick reply - that site is spot on.
I have to say the MR2 is an easy car to speed in. I constantly have to look at the speedo in town and find I've crept up to over forty without feeling like I'm hardly even moving.
Hey Ho! It might slow her down an bit.
Thanks again.
Mike
Treboeth
No problem I picked the site up from  l viewtopic.php?f=11&t=32585 l  this thread bookmarked for future use, glad to help.
The 2 is surprisingly quick and smooth and is easy to build speed up in.
Not as easy as a Skoda Diesel tho`  s:oops: :oops: s:oops:
I know of circumstance where a 2 driver would not attempt to keep up with a Skoda doing 125mph
