Door cable/speaker cable
Started by nathanMR2, February 22, 2011, 21:17
nathanMR2
If your running cable through the door gromet into the cabin where in the car does the wire come out and how do you gain access to it?
Ive had a quick look today and i cant see how to get to the other side of the gromet. Do you just keep feeding it through until it comes out the other end at some point... maybe?
JiMR2
If its not stiff enough to go through easily Nath, attach it to a coat hanger, lube it up and slip it in - works every time  s;) ;) s;)
AKA Cinnamon Jim
nathanMR2
I knew i had been going wrong somewhere all these years   s:oops: :oops: s:oops:    s:oops: :oops: s:oops:    s:lol: :lol: s:lol:
I dont have a problem with sliping it in just wondered where it came out. The cable i have is pretty stiff. Its not speaker cable so may go through without a coat hanger
JiMR2
Quote from: "nathanMR2"I dont have a problem with sliping it in just wondered where it came out.
Soooooooo many things to reply with....   s:lol: :lol: s:lol:
Try putting some fairy liquid on the 2 - 3 " of the end section then try feeding it through mate... had to do this on my old car - worked a treat. Then just cut the last 4" off and job done!  s:D :D s:D
AKA Cinnamon Jim
nathanMR2
I know that bit Jimmy.
If you have a look on the passenger side you cant get your hand up inside the footwell/dash to pull the wire through at all.
Ill have a go when my bits turn up   s:) :) s:)
JiMR2
Can you not push it through from the passenger door, through the grommet into the car that way... at least if you can get it into the cabin it'll be easy enough to grab the end of the cable, rather than trying to fed it through a grommet with no easy accss?
AKA Cinnamon Jim
I'm sure there was a thread on here somewhere about feeding cable into the doors. It was by Buster I think, who was really good with this kind of stuff.
nathanMR2
As far as i can see you can get your hand up to the gromet on the passenger side. Take a look Jim to make sure im not going crazy.
I think i found that post but the pictures are no longer working  s:( :( s:(
I think its one of those where you'll need to keep feeding until it pops out somewhere
manchestermatt1986
I maybe wrong here but does it not come out either behind some
Plastic surround to the left behind the glove box, if not Then possibly atthe top of the passenger footwell carpet? I'd like to know this too as I'm fitting some speakers next couple of weeks
Toyota/TRD Stage 2 Kit - C-one Wing - Hardtop - Injen Induction - Inner Vent LED\'s - Double Din JVC - Armrest - Painted Calipers - Custom Heatshileld - Two Active Subs In Bins - Blitz Nur Spec-S - Team Dynamic 16" - Twin Vocal Speakers On Bin Lids - JSpec Gear Knob - Che Manifold - Angel Eye Fogs -
cclarke99
Don't use a coat hanger as you'll most likely damage something.
philster_d
At least cover it in black tape to reduce the risk of damage.
I spent a long time trying to get mine through. A friend of mine, an electrician, came along and helped me and he did both in like about 5 mins flat.
His secret was.......  he put washing up liquid on the cable ends and just spent a while pushing and feeling them through. It was amazing and just used the wires (and mine were quite thick too)
Phil
