New Aerial - what am I doing wrong?
Started by gavw71, April 8, 2011, 14:44
gavw71
Ok, just fitted repalcement aerial (copy off ebay - no bad reports on here about them yet). Checked there were no broken bits off the whip in the drive cog before fitting new mast - chrome nut off, feed new whip in, turn radio off, motor reels new whip/mast in, refit chrome nut - job done.Then tried aerial up again to check but found that once fully out, the motor continued for another 12 seconds before knocking off. Took aerial out and tried refitting again several times, even using the old tube section off the original mast, all to no success.
I know that the motor times itself out after 12 seconds, so I'm thinking I must have the up/down cycles out of sync, but I'm unsure of what to do. Any advice most welcome as I'm thinking about doing the passenger window switch over ride mod to overcome the problem.
Many thanks,
Gav.
17" Team Dynamics Pro-Race 1.2\'s, TTE lowering springs, front & rear strut top braces, Markiii inlet pipe, K&N panel filter, CHE header, Magnex dual exit exhaust, Dastek Unichip, re-map by Noble Motorsport.
you need to melt the bottom of the mast so the motor goes up and then hits this melted part to stop. yours is currently going all the way back out. have a look at liz arial fix in the how to on doing this. also as an extra step put a bit of insulation tape round  the bit you melt, it will help cusion the blow when the motor hits it, reason i say this is because some peoples fix dont last long as the melted ball on the end breaks off.
richard
gavw71
Not sure that would work as even though the motor continues once the mast is fully up, the whip isn't coming out of the cog, it just makes a grating noise. When the motor times itself out (after about 12 secs), I can turn the radio off and the mast will fully retract, without having to push it in to start it (as happens when a piece of the whip breaks off, leaving it too short and able to come away from the cog when the mast is put up.)
