Amplifier/sub wiring
Started by JiMR2, April 28, 2011, 19:28
JiMR2
So its like Christmas at mine today, got in from work and EVERY THING that i need for my audio install has arrived!
So like a kid ive torn every thing open and found that the amp recomended to me is a mono (as i requested) but is only 1 channel... i have 2 subs...
So after my trembling bottom lip calmed down and before i threw my toys out of the pram i have hit google hard and found the following diagrams...
 m http://akamaipix.crutchfield.com/ca/lea m  ... m_mono.jpg
 m http://a248.e.akamai.net/pix.crutchfiel m  ... m_mono.jpg
Which way should i go? :S
Do these methods look OK to do to you guys? I'm not going to blow my amp/subs to shizzle am I.
Thakns in advance guys.
Jim
AKA Cinnamon Jim
cclarke99
Sorry - I'd like to help but the links don't work for me
Jim, you must know how to post flipping picutres by now!!
m312
What subs/amp is it?
JiMR2
Doh!!!! Forgot the IMG tags!  s:P :P s:P  Sorry guys!
Here they are;
Ok the 8" JBL GTO are:
4 ohm
200w rms
800w peak
And my amps (Alpine MRP500) rating is;
Power Ratings
•800W x 1 Peak
•500W x 1 RMS into 2 Ohms
•300W x 1 RMS into 4 Ohms
AKA Cinnamon Jim
Have a look in the amp literature and see if it details wiring up two subs from the one amp. Alpine are usually comprehensive in the wiring info that comes with their amps and speakers, so you might find their preference detailed for you.
m312
Pretty sure you want the second diagram.
Your subs are 4 ohm, and your amp is stable at 2 ohm.
Here, this link could help as well:
 m http://www.rockfordfosgate.com/rftech/w ... ofer_imp=1 m
The first diagram will give an 8 ohm load to the amp (which it isn't stable with, and it won't be good anyway), because your subs are 4 ohm not 2.
either would work it dont state 8 ohm because that is to old now. secound however is best rated by the amp and will be loud as it a 2 ohm system so go with that just dont turn the power up to much on the amp and no bang should happen
