Original Toyota head unit, any pre-outs?
Started by popcorn, May 9, 2011, 13:43
popcorn
I've been given a set of infinity kappa speakers and alpine amp. I thought the speaker install would be best tackled first, bought a few rolls of flashing tape from screw fix and just finished sound deadening the doors, so I'm almost done there. The next step would be the amp, I was wondering if anyone knows if the standard Toyota stereo has a pre-out on the back? Money is a bit tight at the moment and I can't afford replacing the head unit and there's no point installing the amp at this point unless it does. The cars a post face lift, not sure if that makes any difference though.
Steve
muffdan
Quote from: "popcorn"The cars a post face lift, not sure if that makes any difference though.
It certainly does. The pre-facelift has a Sony unit as standard and that does have front and rear pre-outs on the back, as well as an unconnected amplified rear out. Not sure on the post facelift "fisherprice" unit though.
stargazer30
Just took a peak atthe unit that came out my 2004 MR2.  Theres no RCA outs on it  but its possible one of the four toyota plugs on the back carrys a line out.  I know only one of the four plugs has the power and speaker feeds so I have no idea what the other 3 plugs do.
Still all is not lost for about £20 you can get a line level covertor which converts speaker outputs to an RCA an amp can use.  Don't spend less that than £20 on one though or it'll sound crap.
I'd recommend just buying an aftermarket double din unit though.  JVC do them for about £120 now.
popcorn
Thanks guys. I'll finish the front speakers and worry about the amp further down the line.
m312
I've got a good quality line level convertor in my car, which I connected with the post facelift unit before I upgraded, not doing much with it now though. It's not a for sale or wanted thread though, so if your interested just drop a PM.
I thought I had a pic of the pre facelift Sony unit and found it, as above.
I can't find one for the rear of the Fisher Price unit though.
