fitting originall toyota radio,tape,cd ,panasonic unit back
Started by Anonymous, May 10, 2011, 21:44
hi every one have just bought my second mr2 this time a roadster y reg unfortinatly previos owner removed originall radio, tape,cd player.and fitted single play radio /cd .on top of hiddious alloy blanking plate.have been able to purchase a toyota original unit /panasonic unit.can any body advise me on how to go about removing old radio, and fitting the unit l bought.is it an easy job ?
Fatbloater
Fitting a replacement i a bit of a pig :
 l viewtopic.php?f=47&t=17670 l
Hopefully the previous owner used ISO connectors in which case you can just unplug and plug the old unit back in.
If they cut the cables you're facing a whole world of misery unfortunately.
MR2 \'Red\' Edition - \'54 Reg.  Mods : Clarion FZ709E Single Din Stereo, Pre-cats Removed
"WAX On - WAX Off"
stargazer30
What?  The MR2 has probably the easiest head unit to change I've come accross, and I've done a fair few different cars over the years.  Also that how to guide is overkill you don't need to remove the lower ash tray part at all.  You only need to remove the two side pillars (4 screws in total) and the heater surround (2 screws and 1 plug for the clock).  Then you remove the plastic facia surround and you can lift out the head unit and access the eight screws that bolt the brackets onto it.  Simples.
Put it this way I did my MR2 head unit swap earlier this week and it took me 30 mins flat.
Mind you if they cut the toyota wiring loom connectors off you will have a real problem, you'd prob have to fit a aftermarket double DIN unit instead.
many thanks for the advise on fitting original panasonic /toyota audio unit .can any body advise me where l could purchase a black plastic surround as the one fitted in the car doesnt fit and have trimmed it to fit but am not happy with it the toyota /panasonic unit ,tape ,radio,cd player.has these no on the front of the radio/tape unit,78410,tm4201.the cd player unit has these no on the front of the unit,34245,tf 0411.my car is a2001,the unit came out of a 2002 mr2.
Toyota,
Possibly?
