Cant get FM stations?????
Started by neil c, May 30, 2011, 19:48
neil c
Hello,
have a 2000 mk3 with the standard cd/ radio (double din Sony) for some strange reason I cant get FM stations, the arial is fine ie, goes up n down and i've checked that the arial is plugged into the back of the unit. I can get mw/lw stations but no fm, any ideas?
Ilogik
At a guess you have an imPort, in thAt case the head unit won't have fm. Does it have an fm oprion on the headset? If t is an import you will need to buy a new unit.
Ex: TRD stage 1 TTE Turbo
wbarrwebster
Hi,
I don't profess to know everything about  imported H/Us but my understanding is that they only require a band expander.
B
W. B. Webster
calaerial
Quote from: "wbarrwebster"Hi,
B
This is my understanding also, that said i dont know if band expanders are universal to all H/Us (Probably not) or if not, whether one is available for the standard H/U in the '2.
When i first got mine it had a jap spec radio fitted (also the double DIN Sony unit), best way to tell is if it scans a frequency range other than 87.5 - 108MHz which is used in most countries.
Japan uses 76 - 90MHz, though for some reason my jap spec radio couldnt pick up any of the stations between 87.5MHz and 90, where the 2 ranges overlap and it really should have done. Perhaps there is some technical reason for this, its certainly not the aerial as when i replaced it with another UK Sony (saved getting an adapter) it worked perfectly.
Also unless you've had your car from new, being European doesnt mean it wont have ended up with a jap radio. Mine did because the re-builder who repaired it after its crash in 2003 changed it over from the donor car. Not sure how they tolerated it for 7 years mind you. I couldnt for 7 weeks.
Work in progress - 2001 MR2 Roadster - Silver
Current faults:
General dings
Rotten brake discs
Sticky aerial
