What is the bolt length for a Corky's Breastplate?!
Started by CpnSpankyPantz, June 2, 2011, 12:49
CpnSpankyPantz
Hello,
I'm buying a Corky's breastplate second hand, however it doesn't have the bolts required for fixing. I've had a search but had nothing more concrete than "a bit longer than the current ones", the current bracing bolts are staying on until I try and fit the corkys...
Can anyone provide me with what diameter and length the bolts are? I'll get my some ordered from work...
Thanks!
carl_evs
I've emailed Corky direct in search of an answer. As soon as I get a reply you'll be the first to know!!!
2nd Place - Northern Treasure Hunt
\'52 Lagoon Blue SMT - Likwidart graphics - quite a bit of other stuff...most homemade!!
Quote from: \"nelix\"Sold him my knob, fast payment, thanks
CpnSpankyPantz
Quote from: "carl_evs"I've emailed Corky direct in search of an answer. As soon as I get a reply you'll be the first to know!!!
Thank you very much dude!
carl_evs
Just had a message back from Corky, he says there are M8 x 25 bolts. So am assuming he means M8 by 25mm.
Hope this helps.
CpnSpankyPantz
Quote from: "carl_evs"Just had a message back from Corky, he says there are M8 x 25 bolts. So am assuming he means M8 by 25mm.
Hope this helps.
Thats brilliant, many thanks!
