new headlights
Started by gezza, August 12, 2011, 12:14
gezza
Not sure if this is right does any one no were i can get replacement headlights for facelift model my headlights very clouded and dull thank you.
New ones from MrT for about £300
Some polish for your current ones about £10
Fatbloater
As uktotty advises, polish out the cloudiness.
Go on youtube and search for cloudy headlight polish and it will give you full instructions on how to do it.
Most people use a DA Polisher but you can very easily do it manually with a lot of elbow grease.
MR2 \'Red\' Edition - \'54 Reg.  Mods : Clarion FZ709E Single Din Stereo, Pre-cats Removed
"WAX On - WAX Off"
gezza
Thanks for that any good products i should be looking for and places to get them from thanks.
Mike_V
Quote from: "gezza"Thanks for that any good products i should be looking for and places to get them from thanks.
I use a rubbing compound which you can get anywhere with a little bit of water sprayed on,  I follow that with toothpaste and water, followed by a plastic wax, works fine but it's not permanent.
2004 Red edition in Sable.
