Not enough preouts
Started by manchestermatt1986, September 29, 2011, 12:48
manchestermatt1986
I have got a JVC headunit that has two preouts, i currently have two active subs which ar eusing up the two preouts. However i have purchased some hertz front speakers and tweeters as the 2000 mrs front speakers are kack and have no tweeters.
My problem is iv been advised to amp them to get the most out of them, but im guessing i need another preout for the amp and iv already got both used up. Is there any way around this?
Aapart from losing one of the active subs
Cheers for any advice
Matt
Toyota/TRD Stage 2 Kit - C-one Wing - Hardtop - Injen Induction - Inner Vent LED\'s - Double Din JVC - Armrest - Painted Calipers - Custom Heatshileld - Two Active Subs In Bins - Blitz Nur Spec-S - Team Dynamic 16" - Twin Vocal Speakers On Bin Lids - JSpec Gear Knob - Che Manifold - Angel Eye Fogs -
run a splitter on one set of preouts for both subs
manchestermatt1986
Quote from: "markiii"run a splitter on one set of preouts for both subs
this wont effect the sound quality or watts received by the subs?
preouts are line level, you may need to turn up the gain on teh amp ever so slightly but no major issue
even better if you can daisy chain the amps, does either one have a passthrough?
AmeR
Sounds like you need a new headunit with more outputs!!  s:D :D s:D
manchestermatt1986
Quote from: "AmeR"Sounds like you need a new headunit with more outputs!!  s:D :D s:D
haha i considered that but this headunit does everything i want and more and has done me proud for a few years now.
Quote from: "markiii"preouts are line level, you may need to turn up the gain on the amp ever so slightly but no major issue
Well the teo active subs have built in amps and i dont know what a passthrough is to tell you, sorry. I was hoping to do something like said above. Use 1 preout = run 2 active subs in the bins and then 1 preout = to an amp then the amp to the front speakers/tweeters/crossovers
AmeR
Splitter to the 2 amps sounds more viable and much less work for you. What kind of control do you have over the outputs from the headunit?
stargazer30
Yup, no brainer this one.  Two RCA leads from the HU.  One split to the subs and one to an amp driving the fronts.  Then setup the LPF on the HU to stop the fronts getting anything below from 120hz to 80hz.
PS what Hertz components did you buy?  I just saw the entry level DSKs going for £90 new!
