Opinions needed...
Started by fstsven, April 14, 2004, 18:16
fstsven
Since last night my engine makesa a distinct "whistling" noise.    s:? :? s:?     The closest description I can give is that it sounds a bit like a turbocharger...   (no, I don't have one    s:) :) s:)   )
At first I thought it was somewhere in the transmission, but then I found out the noise is coming from the engine itself since it is heard in gear, in neutral and with the clutch depressed. It also seems rev-related, becoming louder with more revs.  Engine still pulling ok though, and no oil consuption (so far)
Btw I used the search first, but couldn't find my exact "symptoms"    s:( :( s:(
Any comments or ideas would be greatly appreciated...
2004 fire red TOYOTA MR
K&N air filter
BLUEFLAME single exhaust
3.ORACING breastplate
25 kgs extra lightness
DAZ400
I would have a check over the vac pipes and the ISV. Look for splits or perished bits.
SOLD No more 2. Just a bus for the family..........
fstsven
Sorry, the what  s:?: :?: s:?:
Could you explain that; not much of a technician...    s:oops: :oops: s:oops:
Thanx
K&N air filter
