Piggy back ecu . Plug and play ???
Started by Tommygun1, November 9, 2011, 23:35
Tommygun1
Just wondering how people rate these as I don't know what they really do (good or bad) . Would like a bit more performance  but was just thinking of getting it mapped . Which would be better . Also can I do it to a standard car . What's the going rate for a piggy back .
You can't remap a stock ecu
Tommygun1
Ah this helps I'm new to fiddling my car so that helps . Looks like the dasek chip gives the best increase in power with less mod .
stargazer30
Generally you add a chip to a car to supplement and make the most of other performance mods.  You won't gain much chipping a stock car.  Typically add a decent header, sports cat, cat back exhaust and cold air intake then chip it.
What I've found on NA cars is the mods above increase top end BHP but you loose mid range torque in the process.  The chip puts this back and further increases the top end BHP.
Now if you have a turbo then its a different matter!
Tommygun1
I see so its worth sorting out my exhaust and parts first . Ok lads thanks for the help will be doing this in the future then
Tom
dj2k21
Hi Tom, I'm just over Stockton and am usually over teesside park on a Wednesday night so if you need any help with anything or want some advise with things then drop me a message mate. But yes u need to start with the usual mods first before adding piggyback ecus. Personally I don't think there worth the money
Tommygun1
Cheers mate might get in touch and have a mini meet . Any more takers
dj2k21
Yeh you should do, seeing mine might help you decide what you want from yours mate
Stifler
Reviving and older thread as I have a question (due to me not being very smart  s;) ;) s;) ).....
I have the following modifications performed on the car:
* markiii pipe
* K&N panel filter
* Toyo sports decat manifold
* Apexi WS2 exhaust
I'm just starting to look into piggy back ecu's.  I was wondering if there would actually be much of an increase to bhp and torque if I went ahead and spent some money on an ecu (piggy back or stand alone) and mapping?
I had a look in the N/A tuning thread and the bhp figures have some fluctuations so I was just wondering what is the main cause of this difference is?
Any advice would be greatly received  s:) :) s:)   Thanks!
-Mark.
