Anybody have a wiring diagram ?
Started by Ikrana, December 5, 2011, 11:35
Ikrana
Hi everybody!
I am about to do a K20 swap and I need to locate some fuses/wires, It would be of great help if anybody have a wiring diagram,
The wires/fuses/relays I need to locate are;
•Fuel pump 12v source
• Constant 12v source
• Switched 12v: Connect to a switch voltage source
• To Tach: This wire sends the Tachometer RPM signal
• MIL Light:
• From start relay:
• Oil Pressure Light:
• To Speedo:
• Charging light:
So if anybody has any info on were to connect this or have a wiring diagram.
Thanks  s:) :) s:)
cant help with the wires but must say im looking forward to see how the k20 lump goes
PM on its way.
