Vehicle speed signal wiring?
Started by vinp182, December 16, 2011, 20:31
vinp182
Can anyone tell me which wire behind the instrument binacle goes to the vehicle speed signal/sensor please?
Or point me to a wiring diagram please?
Vinny
2001 Nissan Silvia S15 SpecR
1993 Rev4 Turbo mk2 300whp
1994 Rev3 Turbo mk2
2004 Renaultsport Clio182
vinp182
Anyone?
1994 Rev3 Turbo mk2
scottish_turbo
You will need to double check this but I think it might be purple.
EDIT: It is violet and white
Lippy
I need to know the same information tbh as I want to wire my shift light to it so it knows what revs im going, I know you can test for it with a multimeter but its a pain in the backside sometimes
Ex SP240 Owner, looking for another boosted '2
vinp182
Got some info off spyderchat and I'm fairly sure I know which wire it is now
It's purple and white - once I've fitted my heads up display and it's working I'll post up to confirm  s:) :) s:)
1994 Rev3 Turbo mk2
Lippy
That would be mucb appreciated bud cheers.
Nearly got my shift light its just that one wire
SteveJ
Why would you want to connect a shift light to the speedo signal?  s:roll: :roll: s:roll:
vinp182
Quote from: "SteveJ"Why would you want to connect a shift light to the speedo signal?  s:roll: :roll: s:roll:
Good point
My car has a gear shift light but it's not worked since I had the car. I'll have a look at that wiring while I'm there and post that too  s:) :) s:)
1994 Rev3 Turbo mk2
Lippy
Lol its the tachometer wire im after... just realised wrong name... the revs one
scottish_turbo
Quote from: "Lippy"Lol its the tachometer wire I'm after... just realised wrong name... the revs one
That's the white wire.
Lippy
Ive not had chance to look at the wiring on the back of the speedo cluster yet, would it be possable to explain clearer for a noob?
How many plugs are there to the cluster and roughly how many wires? is there a color on the plug or a pin number?
I cant seem to find anywhere that has pictures etc...
scottish_turbo
View this thread to see what it looks like.
The tach wire is white on C6
The speedo wire is violet with a white stripe on A5
