Odyssey Lighweight batteries
Started by Davred, January 7, 2012, 23:19
Davred
Have just had another experience of the "flat battery"! having not used the car for 2 weeks!!
What do you users of the Odyssey battery find with leaving them for 2 or 3 weeks? Do they last, or are they worse then the standard battery when left standing?
My battery is just under 2 years old, yet I had this problem last winter too. I leave the car in a locked garage without the alarm on and car unlocked, so what eats the battery?
W. Red. Black leather. Facelift wheels.Toyo T1R. Pre-cats removed. Matts TTE style chassis brace. 2003 facelift front brace, FK lowering springs, Dev keyhole covers, tte rear grille. Tanabe G-Power Medalion exhaust, JSpec nose badge, mongo's, front strut brace. Matt perf engine rebuild May 2014.
SteveJ
ECU, Stereo, clock, central locking receiver.......... the list goes on for items that are draining the battery all the time.
You have a battery with less than 1/4 of the total capacity of a normal battery - it's not surprising it goes flat. If you are leaving the alarm switched off then why not just disconnect and remove the battery - it should really be in the house on a trickle charger anyway.
Optimate is the way forward
Davred
"You have a battery with less than 1/4 of the total capacity of a normal battery - it's not surprising it goes flat. If you are leaving the alarm switched off then why not just disconnect and remove the battery - it should really be in the house on a trickle charger anyway."
No- misunderstood me!
I have a standard battery. Wondering what users of the Odyssey battery find regards holding charge after a period of standing? Are they any better?
The garage has no power supply and I'm fed up with re-programming radio and clocks every time I take it off to re-charge.
Got a CTek Zafir 90 charger which rescues the battery each time, but why are our batteries so poor compared to every other car I own and have owned?
dcod
I'd run the engine once or twice a week. Good for the battery, good for the engine, good for getting rid of moisture.
Chris H
Quote from: "dcod"I'd run the engine once or twice a week. Good for the battery, good for the engine, good for getting rid of moisture.
Exactly what i do.......if i cant take the car out for a run,i start it up
and turn the heater on full for about 20 mins or so at least once a week......  s:) :) s:)
dcw14mr2
Had to Jump mine today...Its just not lasting 2 weeks now and thats leaving alarm off,  its the smaller Panasonic one so after seeing threads on here i see its the original (6 years- hasn't done too bad)  So Just wondering what the best replacement would be?  Could i get a bigger one with more ooomph to fit in there as theres room?   What have peeps found work best?
\":-(\"EX OWNER of Mr2 Roadster - 2006 - Sable - Silver Hard Top(off) - TRD Spoiler - TTE Bar - TTE Exhaust - Chrome Fuel Flap Surround - Heated Seats - Small Mongo\'s - Devs Caps - Chrome Dial Rings - Lockwood Sills -  Moved Alarm/Spare W Turned -  Switched Aerial -
normanh
Just replaced my battery just before christmas, it was the original Panasonic as supplied in the car. In six years I have only had to charge the battery once and that was in the nasty cold spell of Dec 2010. The battery finally gave up and I replaced it with another Mr T. The battery was almost 11 years old not bad. These days the car doesnt get used much unless its out at weekends so in all never had a problem until recently. I suspect your battery is on its way out now.
norman
