car oxygen o2 single Din
Started by Rusky, February 7, 2012, 11:33
Rusky
Hi guys and girls
I am looking at changing my stock audio for an upgrade, as i use my iphone for music, nav and calls i have come across the oxygen unit.  It is designed solely for the iphone and was curious if anyone has one fitted and if so what do you think about it??  I think the concept is excellent just curious to hear if it works as well as it sounds before i go ahead with it.
got a link?
Rusky
This is the main site  m http://www.oxygenaudio.com/lang-en/231-o-line m   There is a dealer in Huntingdon that supplies and fits them, GT Installs.  Also if you search Car Oxygen o2 on YT there are some vids on there too..
AckersMR2
Just a thought, but if you use your phone for nav then won't it be better up near or on the windscreen rather than attached to the head unit low down on the console?
My only car is a Ducati
Rusky
I understand where you are coming from Ackers but you can angle the iphone which sits in a cradle.  As for it needing to be up by the window, well i dont tend to watch the screen more listen to the directions.  Also most intergrated sat navs tend to be a double din unit in the centre console but i do take your point but dont think it would be an issue.
I'd say it would probably be better up by the windows too. It also doesn't exactly look very pretty but seems like quite a good invention.
Rusky
Points taken guys and girls, i will check it out fully before i go ahead with it and if i do get it then i will post some pics to really fuel the debate.
