Used my mk3 to jumpstart and now no p/s etc
Started by donnac, February 19, 2012, 20:24
donnac
I was trying to jumpstart the mk1 tonight using the roadster, I had the window open and shut the engine off when removing the leads.
then I realized the driver window was stuck open, I had no indicators, the dash lights no longer work and I have no p/steering.  also the central locking is not working now.
Will this be a fuse and if so can anyone tell me where to look as I don't have a handbook   s:cry: :cry: s:cry:
thanks
Donna  s:crazyeyes: :crazyeyes: s:crazyeyes:
2002 Blue Roadster
dj2k21
Open the passenger door, the fuse box is on the end of the dash, just pull thelittlecover off, there is a little sticker saying what fuse does what, sounds like a main fuse though if all those faults are occurring, in that case open the back up, (the engine cover) and check the fuses in that fuse box, very left of the engine bay, can't miss it. Good luci
Die$eL
Theoretically, you should not use a vehicle with a computer box (injected vehicle) to jump another car.
The fluctuation in current can blow the ECU  s:crazyeyes: :crazyeyes: s:crazyeyes:
 (hopefully this is not what happened in your case. Hopefully its just a fuse.)
Its not your top speed that counts but how quick u get to it...
[size=85]05 - XRSi - 160HP at the wheels (Reef) - 15.7 @ Tarlton - 3.12.2010
01 - MR2 Turbo - 339HP at the fly (Reef)
06 - Hilux D4D 4x4 D/Cab - 190HP (Reef) - 1/4 mile - TBC[/size]
donnac
Thanks for the replies,
Seems to be a 100amp brown fuse with a clear see through top thats blown so im now after one of these?
Donna
2002 Blue Roadster
Probably cheaper and quicker than Postman Pat to grab one from your local Mr T.
If a call to them provides no joy, come back and Ill have a ratch.
