Sony WX 570R Removal
Started by Skorps78, March 7, 2012, 05:35
Skorps78
Hi all
having trouble removing the double din to check aerial lead. I've seen some posts on how to remove but would appreciate some pics if anybody has some please?
The surround seems impossible to remo  s:crazyeyes: :crazyeyes: s:crazyeyes:  ve
thanks
2002 Lagoon Blue - JSpec Nose Badge - De-Badged Rear
From memory, I think you have to remove the plastic covering to the console struts on each side, then you can get access to 4 screws on the reverse face of the surround on each side. Also you'll probably need to remove the heater panel just above the head unit as well.
At the bottom of the black dotty legs are two silver plastic caps. These just pull off, the button type rivets are a bluff. Needs a really good yank though!
Undo two crossheads behind. Pull off dotty leg covers.
Remove the 3 heater control knobs and slider knob, just pull off.
Undo two screws behind and remove cover.
You can now get to the four crossheads that hold the stereo. Give it a wiggle to get over the cup holders.
Skorps78
Cheers guys
