Newbie alarm question
Started by 1969, March 12, 2012, 18:45
1969
Be gentle with me as this is a numpty question  s:oops: :oops: s:oops:
I forgot to check when looking at the car!!!
Should my car be fitted with an alarm?
The car is an 04, is says alarm on the window and has a red light inside (I'm not sure if this flashes) but there is no audible bleep when locking/unlocking the car  s:? :? s:?
Treboeth
If its a UK car yes, pop the frunk open have a look under the spare wheel you should see the sounder.
Leave a window down lock the car and then reach inside the car this should set the alarm off.
AmeR
Pop your window down, lock it once with the remote and give it 30 seconds to ensure its armed.... Then stick your arm in and wave it around!! Should make some noise, although if it has the alarm sounder in the stock place it won't be very loud!!  s:oops: :oops: s:oops:
Cheers for the link I think that will be one of the first jobs to be done, I'll give the alarm a check before I part with the rest of my cash!!!
HodJay
I have wondered for a while if my alarm works...so today I had the roof down but windows up, one press of the button on the keys and leant over to touch my seat, floor etc andddddd nothing......tried it again with two clicks of the keys andddddddd nothing.......
I tried it again a little later and it DID go off (quietly thanks to it being in the standard position), so then I tried it one last time and it didn't go off again!!! I waited a few seconds between pressing the key remote and punching the seat and moving the steering wheel etc and nothing! BUT it did go off once...any ideas?
J
Finished hunting for my first MR2, Any advice is still MORE than welcome!! \":D\"
HodJay
Just found this:
 m http://rav4faq.kerkerinck.de/allgemeine ... elgium.pdf m
Has anyone else followed the instructions to change the sensitivity? Could solve my problem!?
J
Treboeth
 l viewtopic.php?f=31&t=22560&p=280699&hilit=alarm+adjustment#p280699 l
Have a look here there is adjustment for the alarm good luck.
HodJay
Ohhh brilliant! Thank you for finding that!!! I'll be giving that ago!  s:) :) s:)
Treboeth
Good good tell us how you get on.
HodJay
Well for the first time since buying my 2 I've gotten my hands dirty!...well, it wasn't a very messy job to be honest haha
Took the 3 bolts out at the bottom of the door and pulled the carpet away from behind the seat
Identified the the alarm sensitivity unit
Finally removed the little round rubber grommet and turned the screw clockwise to make it more sensitive! (the screw being bottom right of the box where all the little while dashes are) I couldn't get a screwdriver in the gap, so used a small cross head drill bit that was slim and long so it fit down the hole in the box (I was surprised how far back the screw was set! Was a real arse to reach)
But I am happy to say that now waving inside the car on both sides and the slight touch of the seat sets the alarm off....and obviously I checked that with the the hood up I could tap all over the hood and car as if it was raining. Hopefully job done and alarm sorted!  s:D :D s:D
Thank you for the help!!!
Tommygun1
I had a look today and couldnt find my alarm sounder . I thought my car was a uk not an import . What eles is different so i can have a check .
Quote from: "Tommygun1"I had a look today and couldnt find my alarm sounder . I thought my car was a uk not an import . What eles is different so i can have a check .
The sounder is under the space saver in the frunk ... you did check there?
Best course of action is to move it out of the frunk and into the area next to the abs system under the plastics next to the frunk   s:wink: :wink: s:wink:
Porsche 718 Boxster
Fiat Panda Cross 4x4 Twinair
Triumph 1200 Thruxtom RS
Ducati 900SS
Tommygun1
Couldnt see it there mate . Think mine is missing it
