In need of some BASS!!!
Started by Skorps78, April 10, 2012, 17:17
Skorps78
Does anyone know of a sub that will fit in a 2 without taking up too much space?
I've heard of an "Under-Dash" sub but can't find one.
2002 Lagoon Blue - JSpec Nose Badge - De-Badged Rear
AckersMR2
Try asking NathanMR2, he used to make them?
http://www.mr2roc.org/phpBB3/viewtopic.php?t=34566#p414779
My only car is a Ducati
AmeR
Definitely recommend the underdash!! Nathan is a top guy too and I'm sure he can give you any pointers / answer questions on the underdash boxes he has made!
Failing that... Get some REALLY good headphones!  s:wink: :wink: s:wink:
stargazer30
+1 for the UD sub.  I have one of Nathans DIY boxes and its the best sub I've had in the MR2 and I've had lots!
With the MR2 since its a convertable good bass is not easy to achieve.  The UD sub seems to do it better than others due to its location, upward firing under the dash.  Its the only sub I've used where it still works with the roof down and the bass just doesn't bleed away.
Personally I've sacrificed both storage bins being that everything I need to store doesn't fit in there anyway.  But an alternative to the underdash is a small sub that goes behind the seat.
If you have yet to make a decision here lies some good options.
 m http://spyderchat.com/forums/showthread ... under+dash m
However If you want the underdash sub, one is for sale, it floated by on the forums more recently and its already on your side of the waters.
 m http://spyderchat.com/forums/showthread ... t=dash+sub m
