new double din installed today
Started by vekma, April 22, 2012, 20:00
vekma
went fairly easy sounds and looks great used iso adaptor and facia side things and stock surround
and when lights on it turns green, will never tire of that
even plays off sd cards look neater than usb sticks
[centre]My Fuel Economy[/centre]
vekma
i now have a xcarlink 12852 for sale if anyone is interested
AckersMR2
Sweet! Not sure about the green though? I'm a stickler for the stereo matching the cars illumination.
My only car is a Ducati
alimcfly
Quote from: "vekma"went fairly easy sounds and looks great used iso adaptor and facia side things and stock surround
LOOKS GREAT
DID IT FIT IN TO THE ORIGINAL FASCIA / SURROUND?
OR DID YOU NEED TO BUY AN FASCIA ADAPTOR PANEL SURROUND KIT ?
HodJay
I really seriously need to do this, I hate messing around with CDs!!!! Was it expensive to do? How long did it take you?
Finished hunting for my first MR2, Any advice is still MORE than welcome!! \":D\"
grsymons
I too would be interested in where you got the side facia adaptors from as I have just bought a very similar JVC unit (KW-DB60AT)
grsymons
A quick search and it looks like we I need a FP-11-08 facia panel for the roadster.
vekma
i used this  m http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 855wt_1163 m
still needed to use old surround
took me about 1hr in all
manchestermatt1986
anywhere i can get the facia adapters but not the iso lead, already got the lead. for a jvc avx double din. excuse this i think i may have just found them. how do i know if  FP-11-08 facia pane is the correct ones?
Toyota/TRD Stage 2 Kit - C-one Wing - Hardtop - Injen Induction - Inner Vent LED\'s - Double Din JVC - Armrest - Painted Calipers - Custom Heatshileld - Two Active Subs In Bins - Blitz Nur Spec-S - Team Dynamic 16" - Twin Vocal Speakers On Bin Lids - JSpec Gear Knob - Che Manifold - Angel Eye Fogs -
vekma
manchestermatt1986
are those the correct ones, i mean there arnt more to choose from. I dont want to order them and have to send them back. i hate returns to ebay
vekma
thats the ones i used for a 2006 mr2 still had to use surround from original stock hu mind
Stereo looks awesome.
I've just ordered a new unit for mine as well as the recommended ebay side facia and connector mentioned a few posts back.
Just a quick question. My facelift stock unit has 4 connectors going to the back of it plus aerial cable. The loom that comes with the side facia only appears to have 2 connectors on it.
Have i ordered the wrong connector kit?
vekma
no you only use two, confused me at the time as well
Brilliant. Thanks. Does the power aerial continue to work? Cheers again.
vekma
Quote from: "The Hanz"Brilliant. Thanks. Does the power aerial continue to work? Cheers again.
yes works the same comes up when hu comes on, i wired mine to passenger window switch and leave it down as never listen to radio
I was thinking of doing that or replacing the coin holder with a rocker switch. Problem is... cant find a blank rocker switch to fit the gap.
tpivette
have sent you a pm re the ipod connecting doo-dah.
vekma
Quote from: "tpivette"have sent you a pm re the ipod connecting doo-dah.
didnt get it sorry
tpivette
sent another asking if you still had the ipod connecting doo-dah and how much your after for it.
Right i have a 2005 mr2 roadster i have a sony double din which i want to replace the standard one with i have been told i need the metal brackets some people say i dont does anyone have any idea exactly what i actually need obviously i need the iso lead but what else also the iso leads all say 2002 to 2004 will this still work a reply would be much appreciated
Craikeybaby
Quote from: "The Hanz"Stereo looks awesome.
I'm in the same boat, got the Connects2 Toyota ISO adapter, which has 2 plugs, but there are 4 going into the OEM headunit. Of the 2 that connect to the adapter one looks like it only has one wire - what appears to be the speaker cables are on other plugs. My car has tweeters in the doors as well as the main speaker, does this make a difference?
I'll try a test fit later, as even though they were ordered at the same time the ISO adapter has arrived, but the facia adapter hasn't.
Which model is this?
Looks great!
Craikeybaby
I tested the ISO adapter the other day, and despite not using 2 of the connectors to the OEM head unit my Aloine head unit seemed to work fine. My concern was that the tweeters wouldn't be connected, but dropping the bass & raising the treble showed they were working. The facia kit arrived today, so I can crack on with fitting it all this afternoon.
Gav_101
Help!!!
I bought a new head unit but when trying to remove the factory one it has a built in what looks like power cable coming from what would be the back left hand corner that goes towards the gear stick.
How do I remove this and reconnect my CD player
