both indicators icons are on?
Started by dansage, June 8, 2012, 06:48
dansage
hi all,
i noticed lastnight that when i indicate, both of my idicator icons on the dash come on at the same time, like the hazards are on?
i checked round and all the bulbs are working, left is left, right is right etc, but the hazards dont work either?
i assume this is because ive fited led wedge bulbs in the indicators on the arches?
i know about possible changing the relay etc, but the indicator relay is behind the dials, and i cant find a replacememnt for this which will cancel out the fault? ive also heard about using can-bus bulbs (which im not) as i thought the relay fix would be easier as i plan to go led all round.
Any help please?
thanks
Black 2000 Mr2. 17 inch alloys, 35mm lowering kit, Full stainless proflow double twin exhaust, K&N cool air induction kit, led light upgrades, blue plasma glow white dial dash, short shift kit, push button start, hard top.
Put proper bulbs in till you get a relay fix?
Oddly I wasn't aware fitting led bulbs could cause this. Sounds like you just have to get these 'canbus' bulbs if you can't find a relay.
Sent from a planet somewhere nearby
Porsche 718 Boxster
Fiat Panda Cross 4x4 Twinair
Triumph 1200 Thruxtom RS
Ducati 900SS
