connecting turbo timer (wiring question)
Started by Anonymous, May 9, 2004, 09:39
the install guide states the follwing connections:-
Red =       key off switch +12v
Yellow =    Ignition switch on +12v
Blue =      ACC or Ignition 2 +12v
Now, looking at Busters wiring post from a few months back (very helpful  :-) :-) :-)  )  it offers the following wires at the ignition harness
12v           white/red &  white/blue
Starter      red +
Ignition     black/yellow +
Second ignition  red/white +
Accessory  pink/blue +
would I be correct in thinking that I should connect as follows:-
timer yellow   to     black/yellow ?
timer blue      to     red/white ?
timer red       to     white/red ?
ant help from anyway who knows for defo would be much appreciated  :-) :-) :-)
it should be black/yellow!
As you want the timer to power up before you turn the engine on so IGN 1 will be fine, this would be the first click on the barrel.
Quote from: "Buster"it should be black/yellow! .
what should???
the wire you want to splice into   s:wink: :wink: s:wink:    s:wink: :wink: s:wink:
