Looking for a connector.
Started by Green Goblin, July 10, 2012, 16:41
Green Goblin
Hi guys, there's a connector next to the windscreenwiperfluidbottle, that's not in use, but has a nice plug in it, protecting it from water. I want to use this connector, to power my drl's (it has current on it when the powers on). But ofcourse, to do that properly, I would have to have the corresponding connector. Only thing I have now, it the partnumber of the plug: 82821‑10050
Anybody any ideas where I might get a fitting connector ?
[centre]1986 MK1 Sherwood Toning - 2000 MK3 Black
Click here for MK1-keychains - MK2-keychains - MK3-keychains[/centre]
Green Goblin
Did some research and apparently it is connected to the A/C compressor. Does anybody have a A/C compressor around and would be willing to take a picture of the connectors on that ?
AC compressor is at the other end of the car. The only thing I can see in that area is a shock sensor for the airbag system (I think)
Green Goblin
Quote from: "dick2ski"AC compressor is at the other end of the car.
Hm, that seems logical. But the connector is listed as "A/C Triple Pressure SW (A/C Dual and
Single Pressure SW)". Number 90980-10943.
Could be the same connector is used front and back though.
mrzwei
I can't really speak for the 2 but the a/c condensor is normally mounted in the front of the car, in front of the radiator and there is usually a fan
Ex.MR2 SMT sadly missed.
Quote from: "mrzwei"I can't really speak for the 2 but the a/c condensor is normally mounted in the front of the car, in front of the radiator and there is usually a fan
True for the 2, but wiring to the fans comes across from the other side.
Heres a shoy of mine by the water bottle.
SteveJ
Quote from: "Green Goblin"
Absolutely correct - it connects to the pressure sw in the A/C pipework at the front of the car (when fitted of course!)
Green Goblin
Ah ! "sw" is switch ofcourse.....
Which is a bummer, because that means there is no male connector (which I already sort of found out, but wanted to be sure.)
Green Goblin
I found pictures of the switch online. SteveJ is 100 % right.
Gentleman, thank you all for your assistance.
Subject has been resolved.
