replacing brake bulbs HELP!
Started by js1mr2, October 3, 2012, 18:18
js1mr2
A colleague at work noticed that my 2 rear brake lights weren't working on my facelift mr2 mk3 when I braked but the top brake strip was. I went to Halfords and bought a set of rear brake lights (code HBU380 - 21/5W PR), got home and came to fit them but they don't look like the correct fitting, does this sound like the correct code?
thanks
Completely wrong bulb and Halfrauds website is wrong too
Have a look here the identify the bulbs you need
 m http://www.regalautobulbs.co.uk/carbulbfinder.php m
Porsche 718 Boxster
Fiat Panda Cross 4x4 Twinair
Triumph 1200 Thruxtom RS
Ducati 900SS
jjr197
I recently had to change mine too. Halfrauds gave me two options, and one was correct. Take your old dead build in so you can compare it in store.
Jimi
"If you're driving with the top up, the storm outside had better have a name!"
js1mr2
thanks, thats what I did and the one they told me I needed was wrong and the bulb in the bulb set I bought for the car was also wrong!
js1mr2
Well having finally fitted the correct bulbs the brake lights still aren't working, any ideas what this could be caused by? all the other lights in the cluster work and the top brake strip on the engine lid
Checked your fuses?
jjr197
Mine needed a good wiggle on the cable before it worked.
js1mr2
thanks for the advice, fuses sorted and all working again   s:D :D s:D
