Help !!!!!
Started by Barney Bear, October 16, 2012, 10:01
Barney Bear
Well got round to fitting the footwell lights and now having a problem
the two star fixings for the roof will not budge tried fluid, star fitting with a spanner and as of yet no joy
any ideas as I would be most grateful   s:D :D s:D
54 Sable, Air con, hardtop
how did you get from the footwell to the roof?
Barney Bear
taking off all the windscreen plastic trim to find a wire   s:) :) s:)
Be really careful with those bolts,they ar put in with threadlock and have been known to shear off. Nathan had to drill one out when one snapped. Always use the best quality tools to fit the head of the bolt you can, to reduce the possibility of rounding off the inner slots. Maybe try turning to tighten a very small amount before undoing.
Personally, I'd try and find an alternative to removing it if I could.
As above... can you not tap into the wires lower down where they are accessible??
on the the door switch itself another idea
nathanMR2
No need to tap into the doom light or door switch. On UK cars you can tap into the wires in the passenger footwell. You're making life very hard for yourself. Removing those hardtop latch bolts are a right pain as Nige said, id be very careful!
Barney Bear
well having now read the advise
going down a different route windscreen plastics all back in place   s:D :D s:D
 thanks for the advise
Quote from: "nathanMR2"No need to tap into the doom light or door switch.
Deffo avoid the DOOM light, that's a whole can of worms you don't want to open. Think apocolypse!   s:flame: :flame: s:flame:    s:flame: :flame: s:flame:    s:lol: :lol: s:lol:
nathanMR2
There are 2 white connectors in the upper part of the footwell. By unconnecting one of those, it will turn your interior light off. This is the one you need to tap into taking a negative switched feed. You then just need to pick up a perm positive on one of the big connectors in the lower part of the footwell. IIRC theres a big white connector and a white wire going into it thats live.
Gif
This may help possibly ?
Linky
Audi TT 200 Tfsi Roadster, Ibis White, Steptronic, Bose, Nav, Climate, Telcon, Nappa Leather
Ex BMW Z4 sDrive30i Auto, Titan Silver
Ex MR2 Roadster, Sahara Sun, Black Leather, Air Con, TTE exhaust
