Facelift rear lights help
Started by mr mr2, October 23, 2012, 10:20
mr mr2
Hi I've got rear facelift rear lights  and as you no the indicator build needs a new holder on it for it to fit in the back of the lights and I'm haveing trouble getting one wot I want to no is does Toyotas other  cars use the same holder on any other car as it might be easy to get O e from a breakers yard thanks David
Excelsior
carlclarke
Quote from: "mr mr2"Hi I've got rear facelift rear lights  and as you no the indicator build needs a new holder on it for it to fit in the back of the lights and I'm haveing trouble getting one wot I want to no is does Toyotas other  cars use the same holder on any other car as it might be easy to get O e from a breakers yard thanks David
I can't answer about other Toyota's. What I did was use my existing PFL harness and replace the indicator holder with one of the single filament holders from the FL harness that came with the rear lights (using bullet connectors so I could always put the original one back if necessary).
mr mr2
If I can't get the hoder can I trim the light case itself ??
Excelsior
AmeR
If you can get a spare set of PFL bulb holders, they can be trimmed slightly to fit but you'll need a new orange bulb
mr mr2
Ok I can trim  the bulb holder to fit but the bulb is to big to fit still can I get a smaller bulb with the Same fitment size but with a smaller bulb so it fits in the hole ??
Excelsior
