Wiring help please
Started by rudycob1, November 20, 2012, 21:49
rudycob1
Does anybody know what the wires coming into the hazard switch are?
I've got the following wires: white/black, white, green with silver stripes and white/black with silver stripes.
I am wanting to replace the switch with a Savage / Trillogy one.
Anybody done this before? Any idea what wire connect were from the car to this type of switch.
Any advise will be appreciated as I am well an truly stuck.
Thanks guys.
On my 2003 wiring diagram, I've got
Incoming: Green/red from the turn fuse and White from the hazard fuse
Outgoing: Green/white and Green into flasher relay, green/yellow into the RH flasher circuit and Green/Black into LH flasher circuit
MOD: PS deletedOP's similar post in Maintenance
rudycob1
Hi Roger
Thanks for that. That is what I have on the wiring diagram that I got on a CD but not on my switch.
Everything as mentioned is coming from the little black thing into the switch, so you can see why I'm confused.
Thanks for your help
