Main Menu
SMT APS sensor repair
Started by Anonymous, December 7, 2012, 11:25
My Toyota MR-S no longer responding to the gas pedal, the cause of failure was in the APS sensor  new APS in Russia worth $ 580  s:scared: :scared: s:scared:    to order 18 days from Japan! Because it is expensive and a long wait, I decided to fix a broken sensor.
1.remove the throttle assembly and unscrew 4 screws APS sensor and remove it
2.gently warmed latch hairdryer and turn down the sides
3.grind down the rivet and remove the plunger
4.remove the lid and sealing ring
5.within the board is 4-pin, heat the soldering iron and remove the switching circuit
6.inside there are contacts that are not pressed to the board and hang out, because of this there is no contact and the gas pedal does not work
7.small screwdriver gently bending up contacts
8.glue drips on the plate with contacts
9.switching circuit wipe with alcohol or solvent and put back
10.soldering iron to solder 4 pins
11.put the O-ring and cover
12.heat the holders and bend, put plunger and gently bump the awl
bolted to the throttle and drive on!))))  s:P :P s:P
traveled 2000 km (1243 mi) all works well  s:) :) s:)
iPap
Great write up and great self diagnostics!
I'm sure that will help someone at some point.
2001, Black MR2, Elise Leather Seats, Aircon and Factory TTE Kit, BC Coilovers, SP Brace, Corkys Front Brace, Devs\' Front Bushes, Rebuilt Toyota 1ZZ Engine, Head and Six Speed Box, Cobra Twin Exhaust, Decat Manifold, Short Shift and Solid Bushes, etc...
Nice work, thanks for the write up  s:) :) s:)
dcod
Wow, what a first post   s:shock: :shock: s:shock:
Welcome ... you're VERY welcome here  s:D :D s:D
simers
Welcome along and great bit of work there fair play to you
Mr2 mk3 1.8vvti 01,93 mirage 1.5,94 pulsar 1.3, 00 306 2.0 hdi
If its not broke, don\'t fix it!!!!
The only way forward is sideways!!!! ;)
Such a good write up deserves it's place here, thankyou for your clear and complete work
Porsche 718 Boxster
Fiat Panda Cross 4x4 Twinair
Triumph 1200 Thruxtom RS
Ducati 900SS
