Is this the correct flashing tape?
Started by s12vea, December 10, 2012, 18:49
s12vea
I'm planning on soundproofing the doors when I update my speaker, is this the flashing tape mentioned in previous posts?
 m http://www.wickes.co.uk/hi-tack-flashin ... vt/243009/ m
Thought I would check before ordering some
Thanks in advance
Ex TTE Turbo
Another one won't hurt  .....
That looks like the stuff Steve.  s:) :) s:)
s12vea
Cheers matey - will order some up  s:) :) s:)
Ex TTE Turbo
Yup. I bought mine from Wickes, albeit a few years ago, so I assume it hasn't changed.
AckersMR2
Seem to recall i bought the 15cm wide one. It was enough to do both the entire doors and stick some to the backs of the door cards too  s;) ;) s;)
My only car is a Ducati
s12vea
Thanks for that I will look out for the wider stuff. Nice little job for Thursday  s:) :) s:)
Ex TTE Turbo
Indeed, they had x10cm and x15cm. I ended up using a roll and a half of 10cm as I thought it would be easier to apply but 1x 15cm would've done both doors.
Yep, the width doesn't really matter, it will all do the job.
stargazer30
Hi Steve,
Its a bad time of year to do this job mind.  It won't stick well in the cold at all and the last thing you want is it peeling off and fouling the window mech.
If you have a nice warm garage you'll be okay, but still roll it out in strips on a warm surface first to get it tacky.
David
Quote from: "stargazer30"Its a bad time of year to do this job mind. It won't stick well in the cold at all and the last thing you want is it peeling off and fouling the window mech.
+1, I did mine on a warm day in summer so had no problems as it was nice and tacky (yes there was a few of those  s:) :) s:) )
Alternatively, you could also use a hair dryer to warm it up.
s12vea
I thought the same about the cold but the car is in a fairly warm garage and I will be using a hair dryer.
May have to put of till nxt week as speakers haven't turned up yet. There is still a possibility they might be delivered tomorrow morning
Ex TTE Turbo
AckersMR2
Quote from: "onion86"Alternatively, you could also use a hair dryer to warm it up.
That's what I did, I did mine in late February outside so pretty cold still, attached it to the car while it was cold so the tack was low making it easier to put in place and then ran a hair dryer over it to warm it up and help it bond.
Just seen this for next week, may be of some use if anyone is thinking of doing this!
 m http://www.lidl.co.uk/cps/rde/SID-200F3 ... il&id=1717 m
DannyN
That's not worth it, the stuff from wickes is twice as wide 15cm and is less than double the price
Black 51 165 BHP - Hardtop ON - Teins - Apexi Power FC - AEM Induction - Crower Cams - Forged Pistons - Iridium Plugs - Zero Manifold - SP Downpipe - H&S - TRD SS - Corkys MSMB - Goodridge - '03 Vents - Devs - Bamas - Crystal Indies - Mongos
Quote from: "DannyN"That's not worth it, the stuff from wickes is twice as wide 15cm and is less than double the price
15cm x 10m is £15.88  m http://www.wickes.co.uk/hi-tack-flashin ... vt/243010/ m  - it did used to be around the £13 mark though
10cm x 10m is £12.28  m http://www.wickes.co.uk/hi-tack-flashin ... vt/243009/ m  - so only 2.5cm wider but over double the price
