Soft top noise.
Started by Anonymous, June 1, 2004, 10:59
Recently, I have noticed a noise from my soft-top roof. It appears to be coming from the thin metal cable that is housed in leather running from right to left, between the outer and in skins of the hood (i.e. directly above my head). I can feel the cable as I run my hand under the centre of the hood. It flapping a lot – particulary on the passenger side and its really annoying.
Has anyone else experienced this, and if so what the solution (if any). Cheers
fstsven
Yes, I have exactly the same...    s:( :( s:(
As to what to do about it...  I've learnt to live with it and accepted that the '2 is never going to be a quiet car    s:roll: :roll: s:roll:
If anyone has a better solution, I'll be glad to hear it    s:) :) s:)
2004 fire red TOYOTA MR
K&N air filter
BLUEFLAME single exhaust
3.ORACING breastplate
25 kgs extra lightness
whay re your driving with the roof up?
it's Gods way of telling you to go topless  :-) :-) :-)
therer the cables that pull the "ears" in. these have velco at the end so make sure that they are connected to the V flaps on the top corners of te roof, had the same noise when i first had the car!
