help fitting my jvc
Started by mr mr2, December 31, 2012, 09:31
mr mr2
got this off santa ive never fitted a stero in my life just want to no do i need any thing to make it work thanks its going in a 2000 reg car
Excelsior
nathanMR2
You are likely to need a Toyota to stereo iso lead. This can be purchased from most motor factors. Halfords charge in the region of £19 each or it can be purchased from eBay for as little as £3.
You will also need a double din tray/holder. This is likely to be a eBay or Internet find as not many places will sell this.
The install is usually fairly straight forward with the above. Any questions give us a shout
Quote from: "nathanMR2"You will also need a double din tray/holder.
It's a double din radio, so In don't think that is needed. I've never done, but assume it just fits in place of the original, plus the ISO conversion of course.
Quote from: "roger"
Yep + 1
also took the original surround and with a little trim that fitted and it look all neat and tidy.
mr mr2
Thanks Ill get the iso lead any probs I will let you no
Excelsior
nathanMR2
I just remember reading that the mounting holes didn't line up properly in this thread
 l viewtopic.php?f=31&t=39223&p=464575&hilit=Double+din+mount#p464575 l
I have never installed a double din myself so others may know better. eBay do additional mounting which I assumed was for this reason but I stand corrected  s;) ;) s;)
dcod
Quote from: "nathanMR2"I just remember reading that the mounting holes didn't line up properly in this thread
I removed the plates off the side of my OEM (Toyota/fujitsu) system and reused them on my Alpine. Needed the Toyota iso from Halfrauds (which said all Toyotas except MR2! But worked fine)
ISO Harness Adaptor PC2-17-4 I think.
 m http://www.halfords.com/webapp/wcs/stor ... 65876#tab1 m
Richard41
That's the harness I used for my jvc and is fine, if its the same size as the KW XR811 dont need a tray holder ( just strip all the bits off the original stereo) but do need the spacer brackets for either side to hide the gap, the original surround just about covers top & bottom and although it doesn't really fit properly like on the original mine hasn't moved.
mr mr2
help   s:? :? s:?  took my old stero out cant put my new one in as cant get the cables to fittheres the old stero  thats the back off the new ive got this cable but wont fit even went to halfords they tried tp sell me the cable i took in so even they cant help me i no some one will no the answerto this help  s:bowdown: :bowdown: s:bowdown:
Excelsior
Richard41
you need two cables to connect it, the new stereo should have come with a cable (single plug - 2 plugs) that plugs into the back of it then the JVC harness bridges between that and the original cables.
mr mr2
this is wot i got with the strereo but none fit in the back off my old unit
Excelsior
mr mr2
first pic is both  cables together 2nd is the end that should fit in the stereo but dont helppppppppppppppppppppppppppppppppppppppppppppppp  s:bowdown: :bowdown: s:bowdown:
Excelsior
mr mr2
This is the connector in the car
Excelsior
In last pic follow cables for a foam bit those are connectors, unplug there and connect the white bits of your halfords plugs there then the black bit of the lead that came with the unit into unit. If still stuck pm me your number and I'll talk you though it.
