My New ICE, Specs and Pics
Started by Anonymous, June 7, 2004, 10:53
They now sounds 200% better than they did when they were first installed, in car pics coming later on!
Well here is what i had fitted on Saturday:
QuoteBolt 50x2 @ 4ohms
75x2 @ 2ohms
150x1 @ 4ohms - 450 Watts Max Power
variable x-over from 40-400Hz
+6db Juice Boost Bass EQ
chrome cover
CT-1 option
QuoteBolt 6.5" Convertible
• Coaxial mount or 3 tweeter mounting styles (flush, surface, wedge)
• 4 ohm with 75 watts RMS/225 watts max
• Mica-injected polypropylene cone
• 3/4" tweeter
• 12db HP/12db LP external crossover
• Optical compression tweeter protection
• Chrome phase plug
• Grills included
QuoteThe original and still the best! Dynamat Original is a thin, lightweight elastic damping material that's designed to improve the acoustical environment of a car by absorbing and eliminating noise causing vibrations. Dynamat speaker kits can be applied to all accessible sheetmetal around the speaker opening. The Dynamat Speaker Kit transforms the flimsy sheet metal car door in to a sloid non-resonant speaker baffle that eliminates distortion and drastically improves mid-bass performance. Dynamat Original Speaker Kit contains no PVC and comes ready to install. It has an adhesive backing and requires no special tools for installation.
The Dynamat Original Speaker Kit includes two sheets measuring 10" x 10" each, which is perfect for most speaker openings.
cool, how much will you be selling it for   s:wink: :wink: s:wink:
Lol, well i will be upgrading eventually, especially now all the wiring is done for me, they did a FAB job of the amp fitting as well.
have to confess I've never heard of bolt, I assume you were going from stock as other than the basscube you were selling I don't remember any speaker upgrades before?
Yeah it was all stock before, makes a HUGE difference.
The Manufacturer is actually a company called Lightning Audio, HalFrauds used to stock their stuff i think. They have inproved quite a lot in their new range apparently.
now lightning I have heard of
You don't rate them by the sounds of things?
no personal experience to be honest. likewise never known anyone who had tried their stuff, to comment.
Buster would be the man for relative merits.
MRMike
Never heard them,   but i've seen some reviews that say the new series is supposed to be relatively good, and the products are made By Rockford Fosgate IIRC
Then.. Blue 350Z
NOW M3 V8
Rockford.... now your talking!
They offered me rockford but it was an extra £200 and it wasn't in stock so decided against it.
Quote from: "MRMike"Never heard them,   but i've seen some reviews that say the new series is supposed to be relatively good, and the products are made By Rockford Fosgate IIRC
No note made by rockford just made buy the same compnay that owns rockford, they have branched into cheaper ICE rather than the expensive rockford.
It not bad stuff but better stuff out there in my view, note to diss what ur put in tho
