Replacement engine 1992 MR2
Started by Anonymous, March 3, 2013, 17:48
Hi Ya'll.  Do any members know if any other Toyota engines will easily fit in the 1992/3 MR2?  My ladyfriend has had the engine blow-up.  She absolutely adores the car and does not want to send it to the breakers.  Failing that, any suggestions on where a decent engine may be sourced from a reliable person or business.  Thank you for looking.  David
ShieldsOnTour
Check out MattPerformance on here --- he can be found in the affiliates section.
One of *them* cars....
[strike]C-one front end & side skirts, TTE spoiler, TTE rear bumper inserts,  Anthracite post-FL wheels on Toyo T1R. 6-speed box. Cobra Quad exhaust. Red leather. Lowered. TTE style bar.  And lots of shinny ....[/strike]
dj2k21
Your not really in the right place mate, this is the mk3 club, urs is a mk2.  However I know the turbo engine and the camry v6 engines are common swaps so good luck
Thank you for your assistance.  David
trevsmr2
As above ,join the mr2 owners club or imoc ,both are more suited to the MK2
plenty of engines or breakers about ,all depends on budget and what you need ,
would you upgrade to the later spec engine for example or even go turbo
whereabouts in Leicester are you ?
