ecu wiring help **urgent**
Started by Anonymous, March 12, 2013, 15:34
im needing to know what wire goes to what on the ecu. im needing this as i have to wire in an aftermarket ecu that is going to need the sensors ie water and air temp, o2 sensors, also injectors, core packs and so on. so can somebody please list all the wires to the standard ecu so i know what wires i need to wire up to my other ecu.
thank you in advance.
would not a wiring diagram be easier?
Quote from: "markiii"would not a wiring diagram be easier?
that would be fine if someone has one that or knows in english what all the pins on the ecu are lol
pm'd ecuakacish to you, I've passed on the Celica pinouts too ... there are a lot of similarities.
Porsche 718 Boxster
Fiat Panda Cross 4x4 Twinair
Triumph 1200 Thruxtom RS
Ducati 900SS
Quote from: "Wabbitkilla"pm'd ecuakacish to you, I've passed on the Celica pinouts too ... there are a lot of similarities.
yes i noticed that thank you but in both its was is the symbol refereing to ie what is VTA and VC for example
in teh library should be teh 2zz swap guide spreadsheet which has the ecu pinouts
see your pm i have all wiring diagrams
