2zz ecu accsepting 1zz keys
Started by steve_co, March 29, 2013, 18:42
steve_co
Hi Im doing a 2zz swap
I want my car to have a stock feel about it like the 2zz was meant to be there in the first place.
so if I swap out ecu to megasquirt or apexi I will lose my immobilizer and alarm and need to buy anther one eating in to my performance fund   s:scared: :scared: s:scared:
My question is can I get my 2zz ecu to accept my keys and rf signal by getting that part cloned off my 1zz ecu to my 2zz ecu so that it will run a 2zz engine but have my original keys.
Im then planning on using a piggyback ecu.
Steve
bap_swcc
Best solution I have found so far is to swap celica and MR2 remote transponders from inside of the key plastic bodies, so the MR2 key (with Celica inner transponder) is used to start the car/manual locks/ignition, and the Celica key is used to open the car/disarm alarm from the remote. Have had no luck with reprogramming the alarm but someone here will have done it, or knows if it can be done, but the above will at least get you up and running.
The Notorious B.A.P.
2004 Black 2zz - I believe in lift power!! (although I do miss the quality woosh of a turbo)
steve_co
Thanks for your reply. I did think of that but the car is scraped so not an option.
Steve
cabbydave
You will have to take the ecu to a specialist to read the eprom from the immo chip then conevrt the code to your chip or buy another ecu that has the origanal keys. There are plenty of breakers on ebay that are breaking Celica 190's
I belive the American ecu didn't have the immobilized.
steve_co
Quote from: "cabbydave"You will have to take the ecu to a specialist to read the eprom from the immo chip then conevrt the code to your chip or buy another ecu that has the origanal keys. There are plenty of breakers on ebay that are breaking Celica 190's
Yer thought as much. hope there compatible
Steve
steve_co
Quote from: "rbuckingham"I belive the American ecu didn't have the immobilized.
Yes they are but I want this to work with the original set-up.
Thanks for your answer
Steve
