Victim of the PreCat Failure!
Started by Anonymous, June 18, 2004, 00:26
Yep! Happened to me. I will be taking the car in monday and hopefully all will go well. Anything I should know before having the work done to it?
make sure your servicing is up to date.  s:D :D s:D
Just for the record, what were/are your symptoms to discover the failure.
i.e Was it a routine check, or loosing oil etc
Hope all goes well anyway, i'm sure with all your knowledge of previous pre-cat failures you'll be armed enough to face MrT. If it is loosing oil, make sure they replace the main cat aswell. Good luck.
Ive had the Car for 3 months. I bought it used as a Certified Uesd car. 40,000 miles, I used it for 3000 miles.
I noticed a clanging noise in the head. As I drove it the the dealer today the engine blew on the freeway. There is a nice big hole in the block now.
Quote from: "DARKSTAR"There is a nice big hole in the block now.
Holy batpoop!!  s:shock: :shock: s:shock:
Got pics?
I actually ran to a liquor Store while waiting for a Tow and bought a throw away. I took some shots when they get developed ill post them. Not sure how well they came out.
For those of you that want to follow up on this there is more details on Spyderchat.
