Interior dome light
Started by rudycob1, June 11, 2013, 22:23
rudycob1
Advise please. My dome light, the one above the interior mirror, does not come on when I open the doors.
The switch on the dome has three positions, on, off and door.
If I turn the switch to on, it works but does not work on the doors position.
Any ideas what could be causing this?
The door switches?
JiMR2
When the engines running, do the door open lights on the dash come on?
Jim
AKA Cinnamon Jim
rudycob1
Thanks guys, I will check these.
Sounds to me like the wire has been snipped.
When i installed my Footwell LEDs i had the exact same problem.
I installed strips of LEDs around the footwells, so when the doors open they all light up green - FUNKY
however, the way i wired them in means you cant have the footwell led's and the dome light on at the same time  s:( :( s:(
I would remove the plastic covering under the glove box and look for a single wire with a push-and-click box on it. I believe its a red and white wire... follow it along and see if anyones cut into it for any reason!
good luck!
Silly suggestion... is there a bulb in there?  s:lol: :lol: s:lol:
Stu... probably, considering when he switches it to "on" the light comes on? :p
Yeah... Monday's aren't my days to shine clearly!!  s:lol: :lol: s:lol:
