Headlight bulb upgrades.
Started by tricky1138, June 27, 2013, 09:57
tricky1138
I've had a quick search around and can't really find the answer so I'll ask direct!
What bulb upgrades have people put on their 2 And what do you think about them?
Not bothered about HID just something like the 50% , 80% brighter ones.
Mine is a fl if that makes a difference.
Also what are the 3 bulb types that are in there?
Thanks.
nathanMR2
I upgraded to Phillips Xremes (H7 bulbs I think) which I have been very happy with. They have been pretty good. I didn't touch the main beam bulbs as it was an additional cost for something that doesn't get used a lot. They only other ones i changed was the side light bulbs for white ultra bright bulbs.
tricky1138
So Phillips Xtreme it is then! Lol.
Gibla
Resurrecting a very old thread (as it's getting dark out there)
Any suggestions that anyone has done in recent years?
H7 for Fl or H4 for Pfl ?
Alternatives to Philips?
2001 Dark Green MR-S (6R4)
Gibla
These are the #1 best sellers on Amazon
OSRAM NIGHT BREAKER LASER H7, +150%
other alternatives
Bosch H7 (477) Plus 120 Gigalight headlight bulbs - 12 V 55 W PX26d
Come on folks give some feedback on YOUR headlight bulbs please, I need to avoid going off the road in deepest darkest mid- Wales
The OSRAM NIGHT BREAKER LASER H7, +150% are what I bought from amazon a year ago but dont think I have driven it in the dark since so cant help you!
MRSwede
On my FL
Low beam = Philips Vision plus
High beam = 50W HID conversion
Gibla
Quote from: MRSwede on November 19, 2021, 14:52On my FL
Hiya, what sort of work was required to fit the HID High Beam bulbs(if other than just a bulb change) and can you recommend any particular brand?
MRSwede
Sin's I'm living in Sweden, not sure if the parts i used can be bought in UK.
The installation was pretty easy, just using + and - from the oem lamp holder.You cannot view this attachment.You cannot view this attachment.
MRSwede
Sorry should be this lamp You cannot view this attachment.
SV-3
Eclectic - not electric
Sony WX-920BT
"Hardtop Cognoscenti"
"Stock Cubed"
"AirCon Aficionado"
"Keeper of the Beeper"
Gibla
Ah well, uprated boggo standard halogen it is then :-( (Good job as already ordered 'em)
MRSwede
God thing that the Swedish MOT don't mind them in the High beam  ;D
I am very happy with my H4 LED upgraded replacements. The primary reason why they work well is because the LED chips are placed in the correct position mimicking a filament. The others do not have this kind of configuration and therefore have glare and no long distance throw like the OEM. They are brighter as good as HID and they cut down on the demands of the electrical system by being very efficient which is great if you use a small lithium battery.
If you want to do some research they are called jdm astar 8th generation  H4 led which are based on the Philips H4 LED bulb design that are more expensive. I also replaced the rear tail light bulbs to LED which are brighter and more instant on unlike the filament type.
puma2
Quote from: Topdownman on November 18, 2021, 18:57The OSRAM NIGHT BREAKER LASER H7, +150% are what I bought from amazon a year ago but dont think I have driven it in the dark since so cant help you!
i use these on my daily definitely better
TheTigerUK
Quote from: puma2 on November 20, 2021, 06:23
I was just looking at these.
Quote from: Dev on November 19, 2021, 19:40If you want to do some research they are called jdm astar 8th generation  H4 led which are based on the Philips H4 LED bulb design that are more expensive. I also replaced the rear tail light bulbs to LED which are brighter and more instant on unlike the filament type.
Do first check MoT concerning LEDs too.
Over hére, in Spain, it is deemed a modification like the HiD.  Even for the rear. Even 6V on the Nimbus. Simply nót allowed to change the type of bulb; NOT. Only solution is the nightbreakers and those are indeed way better.
HID's are about the worst thing since automatic rifles.  You might be able to see, but no other bugger can!
How bright to headlights have to be before they become worthy of ASBOs?
Quote from: Petrus on November 23, 2021, 20:04
Absolutely. I believe the ones I have are molded after the more expensive Philips H4 except a little less bright so they are direct replacements and that might actually have passed certifications depending on where you live.
Quote from: Carolyn on November 23, 2021, 20:42HID's are about the worst thing since automatic rifles.  You might be able to see, but no other bugger can!
 I agree for aftermarket HID bulbs. They do cause glare because they are not designed for non HID housings.
 They will have a short throw with no cut off that blinds oncoming vehicles. This was a big problem over a decade ago with these kits for boy racers.
There are those that also fit them into FL cars which have the projector not made for it.
 HID on cars designed for them are just fine and better in many ways because of the color temp they produce.
 HIDs are now a thing of the past as they are replaced by the jewel LED lighting you find in newer cars that almost never need replacement.
  As far as automatic rifles I agree, it wastes ammo and that is why some militaries have switched to select fire.
BahnStormer
Officially not allowed LEDs: no chance in the PFL cars (reflector unit) and officially also not in the FL cars (projector), but if you can install them and get a perfect beam pattern you will be allowed.
Quote from: BahnStormer on November 24, 2021, 15:32
 If that is the caveat then the LED h4 bulbs that I have should pass or the Phillips that they are modeled after to be H4 replacements. They were designed to mimic the filament of an halogen H4 bulb so that it works with the reflector to give it the same beam pattern.
 If anyone would like more information on the Philips H4 LED replacements  here is a good read. I am sure it can be purchased on your side. The electrical load on the alternator vanishes, thats how impressive this technology is.
https://www.xenondepot.com/Philips-12953BWX2-H4-LED-Bulb-Review
BahnStormer
Quote from: Dev on November 24, 2021, 19:32
It means that technically they would still be illegal, however from personal experience, if the beam pattern is correct and colour is close to a Hologen (ideally 4300K-5000K, 6000K absolute max), then they will most likely pass an MOT and unlikely to be stopped by the police.
