Turbo Wastegate Actuator Pipe
Started by nathanMR2, August 19, 2013, 20:18
nathanMR2
I'm looking to replace my actuator pipe on my TTE Turbo. It's a Garrett T25 turbo. Does anyone know the internal diameter size pipe that is needed?
It's around 2 to 2.5mm, measure the nipple at each end and look up samco pipes.
nathanMR2
I'm not with the car mate. I'm in London. I want to order some pipe for when I go back up to the midlands and its there for when I get back.
I know it's pretty right from when I removed it the other day. I just failed to reassure it  s:( :( s:(
Typically on the PE Turbo, Mass, and C2 kits it's 2 or 2.5, just depends how long it is.
I'm hoping someone comes along a and responds with "It is X mm".
nathanMR2
2.5 seems pretty small. I remember the pipe being around 12mm outer. I can't find anything of those sizes  s:? :? s:?
I think mine is 4 - 5 mm I can check in the morning, but I couldn't say if its the same size as yours.
stargazer30
Quote from: "nathanMR2"2.5 seems pretty small. I remember the pipe being around 12mm outer. I can't find anything of those sizes  s:? :? s:?
I just this pipe off my TTE last week. No ways its 2.5mm thats tiny.  Its at least 5mm internal.
nathanMR2
My guess it was about 3-4mm. I've searched online but I can't seem to find anything
nathanMR2
Just for the record the pipe is 6mm internal diameter and 12mm external diameter reinforced pipe
6mm is enormous for that job!
nathanMR2
It's a pretty tight fit over the nipple nic. It looks like the pipe in the TTE fitting instructions. I have however measured it with digital callipers
stupink
6mm is not enormous at all imo, if you have a tiny pipe feeding the actuator then you're going to get actuator lag, and introduce overboost.(a good way to achieve it if you want it, or to use a lonnnnnnnnnnggggggggggggggg pipe)
