Front fog light switch
Started by carlclarke, September 18, 2013, 20:14
carlclarke
Does anyone have a part number for the correct front fog light switch that I would use with the fog lights for a TTE bumper? I am assuming that front fog lights are incorporated into the light stalk on face lift cars but if not then a part number for a dashboard switch for a face lift would probably be ok too. Failing that if anyone has a source for a non-Toyota item that matches and will fit in one of the rectangular cut-outs please?
Jandaw
Can't help with a part number but can confirm that the FL fog light switch is on the right hand side of the dash and not on the lights stalk.
minimike
Sure you will get one of these off Ebay for less than a tenner.
Mike.
2006 red, 2006 silver TF212, 2003 black, 2001 black
carlclarke
Quote from: "Jandaw"Can't help with a part number but can confirm that the FL fog light switch is on the right hand side of the dash and not on the lights stalk.
Thanks - that is useful at least I can get my local Toyota dealer to look it up if nobody has a part number.
carlclarke
Quote from: "minimike"Sure you will get one of these off Ebay for less than a tenner.
Mike.
I was looking but I can only find door lock and electric window deactivation so far - that is why I assumed it was on the stalk. Anyway at least I know there is one now  s:) :) s:)
trevsmr2
84162   SWITCH, FRONT FOG LAMP
84160-44010      1   $67.73
carlclarke
Quote from: "trevsmr2"84162   SWITCH, FRONT FOG LAMP
Thanks and Wow! I hope it is going to be a beautiful switch for that much money  s:) :) s:)
brianorme1986
can i ask how much the switch was please?? thanks
carlclarke
Quote from: "brianorme1986"can i ask how much the switch was please?? thanks
After a little research I found out that it is the same switch as used on Toyota Picnic  s:lol: :lol: s:lol:  and picked a used one up on eBay for £6.99 + p&p.
Interestingly the Toyota Rav4 (94-00) has a hazard light switch that is unfortunately horizontally mounted but a otherwise perfect match, I will need to check out the connections to see if it is plug in compatible but if so then I could use it to relocate the existing one that has a prime location in the centre of the dash and would look good for something like a start button.
