Door Mirror Disassembly
Started by carlclarke, September 26, 2013, 10:34
carlclarke
I looked in the workshop manual and did some googling but I cannot find any information about how you can disassemble the door mirror, I want to separate the upper part that contains the mirror and motor from the lower part that bolts to the door. Has anyone done this who can give me some ideas or advice? The big spring behind the mirror motor looks a bit troublesome.
redarrow
Bring the window down there a bolt/ nut under
The rubber right where the mirror sits
[size=85]These are the dreaded code your get with cheap 02 sensors.
P0135 drivers side position. (o2 sensor heater malfunction (bank 1 sensor 1)
P0155 passengers side position. (o2 sensor heater malfunction (bank 2 sensor 1)
P0141 passengers side down below exhaust position. (o2 sensor heater malfunction (bank 1 sensor 2[/size]
