Low revs
Started by LeeUK, July 19, 2004, 20:08
LeeUK
My car on two occasions has idled at extremely low revs and was on the verge of stalling. (300-800rpm)
It also mis-fired a few times whilst driving.
Is this a know problem or am I on my own?
If it's not running right due to the minor mods i've made would a dastek fix the broblem?
Many thanks
Lee
[size=100]JELBE[/size]
[/color]
Quote from: "LeeUK"My car on two occasions has idled at extremely low revs and was on the verge of stalling.
That's quite normal...the ECU tries to lower the idle as low as it can and sometimes it can feel like it's about to stall, but it never does.
I don't think Dastek can help with the idle. You'd need a PFC or another standalone...
Also, I don't see why Apexi intake or an exhaust would cause that  s:? :? s:?
I took mine to MrT when it was doing this a while ago adn they said and i quote "revs the nuts off it when it does it mate, its the ecu "learning your driving style"" might be complete BS but does seem to sort it lol
GSB
Quote from: "Tem"Also, I don't see why Apexi intake or an exhaust would cause that  s:? :? s:?
Air leak in the Apexi? Any air bypassing the MAF will confuse things.
Quote from: "GSB"Air leak in the Apexi? Any air bypassing the MAF will confuse things.
That's true, I didn't think of install bugs  s:roll: :roll: s:roll:
